Radio and gear shift area lights will not work
132,354 MILES • 2WD • AUTOMATIC
MEDICJEN
I found the fuse box in my car. I suspect a fuse is the issue, however I cannot find a diagram that matches my fuse box.
Jan 17, 2020 at 5:03 AM
  • 110,246 POSTS
I attached what I have. If you look at the last pic, that is the fuse from my wiring schematic for instrument illumination (interior lights). Let me know if it helps or if you have questions.
Here are a few links you may find helpful:
Let me know if this helps.
Jan 17, 2020 at 2:12 PM
