Fuse keeps blowing?
99,040 MILES • AUTOMATIC
FTHOMAS
  • 5 POSTS
Dashboard lights will not come on. The right taillight will not come on. The brake, signal, reverse lights all work when needed but taillight will not come on. Changed the fuse but they keep blowing.
Mar 15, 2023 at 10:51 PM
MIKE H R
  • 3,094 POSTS
There may be a bad wire or a corroded light socket that when you turn the lights on it shorts out the fuse. Check the bulb socket and bulb. Look for any frayed wires or crossed wires. The dash lights are the same fuse as the taillights. Start by checking the right taillight assembly.
Mar 16, 2023 at 1:17 AM
FTHOMAS
  • 5 POSTS
Thank you so much. Could that also mean I need a new taillight?
Mar 16, 2023 at 3:04 AM
MIKE H R
  • 3,094 POSTS
No, check the wiring and bulb, you can get the whole wiring harness if you need to but check the wiring. The short might be what is blowing the fuses.
Mar 16, 2023 at 6:51 AM
FTHOMAS
  • 5 POSTS
Okay, thank you so much.
Mar 16, 2023 at 6:52 AM
  • 110,248 POSTS
I noticed we haven't heard from you for a couple of days. Have you been able to make any progress?
If not, could you let us know the fuses that are failing? Also, if you remove the affected bulbs and turn the lights on, does the fuse still fail?
Let us know.
Mar 18, 2023 at 2:11 PM
MIKE H R
  • 3,094 POSTS
How did you make out? Let me know.
Mike
Mar 21, 2023 at 4:27 AM
FTHOMAS
  • 5 POSTS
Dash is still out. I changed the light that went out, but it is still a problem. I changed the fuse as well. It is fuse 10 but it blew as soon as I turned the lights on.
Mar 21, 2023 at 7:06 AM
FTHOMAS
  • 5 POSTS
Have not been able to go to my car guy. But I will this weekend.
Mar 21, 2023 at 7:07 AM
MIKE H R
  • 3,094 POSTS
There has to be something shorting out.
Mar 21, 2023 at 9:38 AM
