Window fuse location
1,000,000 MILES • 4 CYL • FWD
JENNIFER GADDIS
Where is the fuses for the windows?
Jun 18, 2017 at 11:31 PM
HMAC300
  • 48,601 POSTS
It sounds like a fuse or relay is not working here are two guides and the fuse and relay locations so you can get it fixed.
and
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Jun 18, 2017 at 11:54 PM
BOOPERIII
Thanks for this post the fuse was blown! all set :)
Mar 2, 2019 at 6:45 AM
TRACEY CARPENTER
Electrical problem
2000 Kia Sportage 4 cyl Two Wheel Drive Manual
How do I find the fuse for my power windows?
Mar 2, 2019 at 6:45 AM (Merged)
DAVE H
  • 13,383 POSTS
https://images.2carpros.com/forum/automotive_pictures/266999_kia_34.jpg
SABATINO DERICO
My power windows will not work I used a new fuse 30A and 40A no luck.
Mar 2, 2019 at 6:46 AM (Merged)
RENEE L
  • 1,260 POSTS
There is a relay that goes bad, here is a wiring diagram to help you.
Please let us know what you find so it can help others.
KIA2001
Driver's side master control panel unable to power up/down the passengers and back windows.
DAVE H
  • 13,383 POSTS
MASTER POWER WINDOW SWITCH OPERATES DRIVER'S WINDOW ONLY Sportage Turn ignition on. Using voltmeter connected to ground, backprobe and ensure battery voltage exists at specified wire color terminals of master power window switch while operating switch. See WINDOW SWITCH POWER DISTRIBUTION (SPORTAGE) table. See Fig. 1 . If battery voltage exists, go to next step. If battery voltage does not exist, check master power window switch operation. See MASTER POWER WINDOW SWITCH under COMPONENT TESTS. Repair or replace as necessary. Retest system. Using voltmeter connected to ground, backprobe and ensure battery voltage exists at each individual passenger window switch while operating master switch. See WINDOW SWITCH POWER DISTRIBUTION (SPORTAGE) table. If battery voltage exists, go to next step. If battery voltage does not exist, repair open or short in appropriate power feed circuit to passenger window switch. Retest system. While operating master switch, ensure battery voltage exists at Pink wire (switch position UP), then Green wire (switch position DOWN) at each passenger window switch connector. See Fig. 2 . If battery voltage exists, go to next step. If battery voltage does not exist at one or more switches, check appropriate window switch operation. See PASSENGER POWER WINDOW SWITCHES under COMPONENT TESTS. Retest system. While operating master switch, ensure battery voltage exists at Pink wire (switch position UP), then Green wire (switch position DOWN) at each passenger window motor. See Fig. 2 . If battery voltage exists, replace appropriate window motor. If battery voltage does not exist at one or more motors, repair appropriate open or shorted wire between passenger window switch and window motor. Retest system.
https://images.2carpros.com/forum/automotive_pictures/266999_kia_47.jpg
JROLLIII
The rear passenger window will not roll up (power windows). The other windows work, and the problem window will roll down. What are the likely culprits, the motor, the switch (it won't roll up from the main switch by the driver or the switch in the rear), the regulator, or soomething else? Is there a way to get the window to go up manually while I get up the money for the repair?
KHLOW2008
  • 41,812 POSTS
If you can roll it down, the problem is not with the motor and it could be both switches are bad.
To crank it up, remove the door panel.
Disconnect the motor wire connector.
Apply battery voltage to one terminal of the motor connector and ground the other. Reverse the polarity if the window is not going up.
DAN LINCOLN
  • 7 POSTS
some times the opposite door switch can be taken out and brought over to the problem side. you could even carry the trim panel to the problem side and plug the switch in to raise the window. i personally, like to observe the interior light and then press the window switch. if i can see a dimming in the light it indicates power flowed while i had the switch pressed. no dim? then no power trying to move the motor. coffee has a strange attraction to window switches. they have no idea what caused it on mine
