Fuse number for TPMS sensor light
100,000 MILES • 2.4L • 4 CYL • AUTOMATIC
CHARLIE TIPPE
is there a dedicated fuse for the dash light for the tire pressure sensor, TPMS? if so what number is the fuse? and exactly were is the fuse located? thanks very much, Charlie.
Jan 24, 2017 at 11:05 AM
STEVE W.
  • 15,407 POSTS
No dedicated fuse for the TPMS. It is fed off of the same fuse that powers the ECU and Ignition. You will find that most factory TPMS systems are powered in a similar manner or are actually part of another module (GM likes to use the key-less entry receiver for the TPMS unit). That is to prevent people from just "pulling the fuse".
Jan 24, 2017 at 8:10 PM
