What type fuse for driver’s side window and where is it located?
130,000 MILES • 2WD • MANUAL
MICHRYAN26
Hi, can you tell me where to locate it and what kind of fuse to use.
Thank you!
Michele
Aug 23, 2021 at 1:08 AM
  • 110,248 POSTS
It will be located in the fuse box in the vehicle, left side. If you look below, I attached the wiring schematic of the power windows. I highlighted the fuse going to the left front window.
If you look at pic 3, I included a pic of the location and which fuse to check. Note that when checking a fuse, if the fuse is good, make sure there is power to it. Here is a link you may find helpful:
The fuse is 30 Amp.
Aug 23, 2021 at 2:01 PM
MICHRYAN26
Thank you!
Aug 23, 2021 at 8:39 PM
  • 110,248 POSTS
You are very welcome. If possible, let me know if you were able to find and replace it. If I don't hear back from you, please feel free to come back anytime in the future if you have questions need help. You are always welcome here.
Take good care of yourself,
Aug 24, 2021 at 12:04 PM
MICHRYAN26
I found it but it was good. My window wouldn’t go up once. I turned the car off and then on and it went up. It happened three other times and that’s when I checked the fuse. It seemed good and I didn’t replace it, but the window is working. Maybe me taking it out and putting it back in. Not sure…
Thanks again!
Aug 25, 2021 at 6:00 AM
  • 110,248 POSTS
It is very possible that there was a loose or corroded connection that is now making better contact. Regardless, I'm glad to hear it's working for you.
Let me know if that changes or if you need help.
Aug 25, 2021 at 11:04 AM
