Fuse for cylinders 1-7 keeps blowing
205,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DAVID TOWNE
  • 10 POSTS
The fuse for bank that runs cylinders 1-7 keeps blowing as soon as I drive ..
Jul 25, 2021 at 12:48 PM
  • 110,248 POSTS
Hi Dave,
Could you let me know what code you have? As far as a fuse, it could be ignition related, fuel related, injector related, and so on. So, I'm not sure exactly what is happening.
Jul 25, 2021 at 1:32 PM
DAVID TOWNE
  • 10 POSTS
I don’t remember exactly what code it was but it had something to do with injectors.
Jul 25, 2021 at 2:18 PM
  • 110,248 POSTS
Okay, no problem. Can you tell me which fuse is blowing? If you look at pic 2, I highlighted two fuses. Pics 2 and 3 are a very small portion of the powertrain management. That is why I'm trying to narrow it down.
Interestingly, the injector fuses are hot at all times. Does the fuse blow as soon as you install a fuse or does the key need turned on?
If it blows as soon as it's plugged in, try disconnecting one injector at a time to see if there is one that prevents it from blowing.
Jul 25, 2021 at 2:42 PM
DAVID TOWNE
  • 10 POSTS
It’s the fuse marked 2*.
Jul 25, 2021 at 2:59 PM
DAVID TOWNE
  • 10 POSTS
Under hood.
Jul 25, 2021 at 3:00 PM
DAVID TOWNE
  • 10 POSTS
And it blows when I’m driving. like not even a minute after running . Then bam, no 1,3,5,7.
  • 110,248 POSTS
Okay, here is what I want you to do. I need you to first disconnect the battery negative terminal. Then, one at a time, disconnect one of the affected injectors at a time.
Each of the injectors receives 12v constantly when the battery is connected via the pink wire. What I need you to do is check for continuity to ground (resistance) in each pink wire for the 4 cylinders affected. I need to know if there is a short to ground.
When you check, place one lead of the multimeter (ohms) on a good ground under the hood and the other lead on the pink wire at the injector. There shouldn't be continuity to ground. If there is, then we have a short in the affected wire.
Afterthought... If you want, just pull the fuse that blows rather than disconnecting the battery. That will make it easier.
Let me know what you find.
Here are a couple of links you may find helpful:
Jul 26, 2021 at 11:27 AM
DAVID TOWNE
  • 10 POSTS
Thank you for your time. I found the culprit. there was a wire with the smallest bare spot. heater core hose was leaking slowly , filled up the wire protecting plastic and when it reached the bare spot. well a short of course, lol, so I fixed heater core hose fitting and dried up all the water and liquid taped it. thank for all your help.
Jul 26, 2021 at 10:58 PM
  • 110,248 POSTS
You are very welcome. I'm glad you found the problem. Electrical issues can become a nightmare. My favorite was an ABS light stuck on (GMC Envoy). Everything tested perfectly.
Well, the A/C clutch pulley wore through and cut the signal wire to the inside of the vehicle. It took five minutes to fix the problem and 5 hours of diagnostics. Ugh!!! LOL
Regardless, please feel free to come back anytime in the future if you have questions. You are always welcome here.
Take good care of yourself,
Jul 27, 2021 at 1:05 PM
