Fuse does not test current
145,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GDRAGON
  • 8 POSTS
Fuse 37 and 38 does not have current.
Mar 22, 2019 at 4:20 PM
Good morning,
Do you have voltage at the fuses on both sides?
What is the exact reason you have this concern?
Mar 22, 2019 at 10:10 PM
SCGRANTURISMO
  • 4,897 POSTS
If the fuse is dead, just replace it with a fuse of the same size and ampere rating. Fuse #37 is a 15A fuse and fuse #38 is a 5A fuse. If you are unfamiliar with how to change a fuse, please go to the link down below.
Please let us know if there is anything else that we can help you with.
Thanks,
Alex
2CarPros
Mar 22, 2019 at 10:12 PM
GDRAGON
  • 8 POSTS
I have been having trouble figuring out why my car shuts off when put in drive from out of idle as I step on brake. I was told by street mechanic brake booster. so changed booster and car still stalls as i step on brake. I had some problem with battery drain a week be for this problem. i have checked some ground wires and that took care of the battery drain, but now notice that fuse #37, 38 do not test current. any help I will be appreciate!
Mar 23, 2019 at 4:47 AM
Got it.
Did you check for voltage at the fuses with a test light or voltmeter?
Mar 23, 2019 at 5:06 AM
GDRAGON
  • 8 POSTS
Yes I did, did not get any current with key on.
Mar 23, 2019 at 6:37 AM
I asked about voltage not current. You need a test light or voltmeter to measure voltage.
Mar 23, 2019 at 6:43 AM
GDRAGON
  • 8 POSTS
well yea, no voltage at fuse.I changed fuse but still nothing.What voltage reading should I be looking for just encase as I do wiggle wire test.
Mar 23, 2019 at 3:31 PM
12 volts.
Mar 23, 2019 at 5:07 PM
GDRAGON
  • 8 POSTS
First of all thank you for the information you have been providing. The Ford manual states that fuse 37,38 is transmission position switch, GEM park neutral switch.What are they and where are they located?
Mar 24, 2019 at 9:59 AM
Did you verify that the fuses are the cause of the draw?
GEM module
REMOVAL
1. Disconnect the battery ground cable. For additional information, refer to Battery.
CAUTION:
^ Prior to removal of the module, it is necessary to upload module configuration information to the appropriate scan tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Module Communication Network (Information Bus).
^ Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
2. Remove the instrument panel steering column cover.
1 Unlock the retainers.
2 Remove the instrument panel steering column cover.
CAUTION: Use care when removing the instrument panel steering column cover or damage to the cover locating tab may occur.
3. Loosen the bolts and disconnect the bulkhead connectors from the instrument panel fuse junction panel.
4. Position the instrument panel fuse junction panel aside.
1 Remove the nuts.
2 Remove the bolts.
5. Remove the Generic Electronic Module (GEM).
1 Disconnect the electrical connectors.
2 Remove the screws.
3 Remove the GEM.
INSTALLATION
1. To install, reverse the removal procedure.
CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the scan tool equipment into the new module. For additional information, refer to Module Communication Network (Information Bus).
The neutral switch is on top of the transmission under the hood.
Mar 24, 2019 at 8:13 PM
