fuse box panel located?
215,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JORGE GOMEZ
can't find fuse box. I am having troubles with the blinkers
Oct 2, 2021 at 2:08 AM
This fuse panel is located on driver side behind the IP.
Here is a guide that will help with testing and replacing fuses in case you need this:
I am attaching the location view below. This is a pretty confusing diagram, but you are looking at the back side of the IP.
Please let us know if you have other questions. Thanks
Oct 2, 2021 at 12:00 PM
