Where is the inside fuse panel located?
170,000 MILES • AUTOMATIC
ANMFWS
My heater worked perfect then all of a sudden it won't blow HeaT! The window defroster still defrosts but only with cool air! What could be the reason? Where is the inside fuse panel located?
Feb 3, 2016 at 11:18 PM
You have what is called an air mix damper which basically is a cable attached to the handle that adjusts the temp. I suspect this cable has come off, broken, or is out of adjustment. So there would not be a fuse issue on this concern.
I attached the process below with this information so that you can adjust the cable.
Let's run through this and go from there.
Thanks
Jan 29, 2021 at 7:26 AM
