Drivers side window is not working
105,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
CMCCARTNEY
I think it might be a fuse but they are not labeled.Can you send me the fuse box diagram please?
Jun 7, 2019 at 8:49 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I hate to say it, but one fuse covers all the window operations. If others are working, chances are it isn't a fuse. I tried to look up a pic of the fuse box, but it wasn't shown. So, I checked wiring schematics to see where power was supplied from. You are going to need to find fuse number 10 in the fuse box under the dash. I have attached two pics from the wiring schematic for you. The first shows the fuse I am referring to, and the second shows that power is supplied via a CPU to all windows. The power comes from the fuse I mentioned.
Check the fuse and let me know what you find. We may have to check the switch in the door to see if it is the problem.
Here are a few general links that you may find helpful when checking fuses and electrical components:
____________________________________________
Jun 7, 2019 at 2:30 PM
CMCCARTNEY
Thank you for responding. It took some digging and but I found this link (below) Its listed as fuse 10 under the dash and fuse H under the hood.
http://knigaproavto.ru/shemy/en/nissan/altima/673-2007-2012-nissan-altima-fuse-box-diagram.html
Jun 7, 2019 at 3:20 PM
  • 110,248 POSTS
Welcome back:
Happy to help. Did you replace the fuse or find it was bad? If it was bad, did it take care of the problem?
Jun 7, 2019 at 4:08 PM
CMCCARTNEY
I only pulled the one under the hood and it looked good. I'll check under the dash tomorrow and let you know.
Jun 7, 2019 at 4:11 PM
  • 110,248 POSTS
Sounds like a plan. Honestly, I think Nissan is trying to hide information on fuse locations. I pulled up a PDF file of the entire owners manual and found the section on fuses 8-22 and it tells nothing more than how to remove one and what not to do. No pictures to locate. Ugh!
Let me know what you find.
Jun 7, 2019 at 4:22 PM
