Fuse Box
100,000 MILES
CARDUMMY93
My fuses inside the car donesn't read with a circuit tester but the outside fuses in the box can be read and light up. How do I fix this issue? Thanks!
May 13, 2022 at 6:21 AM
SQM
  • 6,383 POSTS
Are you experiencing any specific issues?
One thing to keep in mind, if you are unable to find a good ground, you won't be able to test the fuses. Try a different spot for ground or maybe the same spot that you used to test the under-hood fuses.
Here is a helpful guide:
Let me know what you find or if you have any questions.
May 13, 2022 at 6:28 AM
CARDUMMY93
Thank you for responding so quickly.
I am having an issue with the radio, windows, dashboard, brake lights, as well as the shifter not being able to move out of park unless i press the button to the side with a screwdriver. I think it's related to the fuse box inside.
I had a family mechanic check it yesterday and he had the same ground when he checked the front fuses which were able to be read and had the same issue with the inside fuses not being able to read.
May 13, 2022 at 6:40 AM
SQM
  • 6,383 POSTS
Have you pulled out the fuses to see if they are blown?
Also not being able to shift out of park could be due to a faulty shift interlock solenoid, which removes the lock when the brake pedal gets depressed. Also could be due to not getting power to the solenoid due to bad fuse.
May 13, 2022 at 8:00 AM
CARDUMMY93
I have, they aren't blown. All of them in the inside fuse box can't be read but they're not blown, is there a fuse that brings power to the inside fuse box?
Or a main fuse that powers the fuses inside.
Okay great, that's good to note.
May 13, 2022 at 10:43 AM
SQM
  • 6,383 POSTS
It is possible to have a short in the main harness for the fuse box.
Check for continuity on the harness for the fuse box. Take a look at the diagrams below for the harness location.
May 13, 2022 at 4:15 PM
