the INJ fuse keep blowing?
2007 TOYOTA CAMRY
300,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JOE1953
  • 773 POSTS
why the INJ fuse keep blowing and how do I find the problem? I done replace the fuse 3 time. no spark no fuel pump sound when turn key on no start. I use my test light to check for a short at the fuse box inside the car I hook the clip end to battery positive and the pointed end to one side of the fuse box socket with key off.
Apr 7, 2026 at 11:40 AM
  • CERTIFIED EXPERT
  • 53,855 POSTS
So this happens when one of the injectors is shorting out. I would remove them and run this test from this guide.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Apr 8, 2026 at 9:54 AM
JOE1953
  • 773 POSTS
no 12V at the Injectors and coils I'm not sure is the coils is causing the problem no 12V at the coils. when the problem first started the engine would start up and die immediately and I scann for codes the codes was p0351-p0354.
Apr 12, 2026 at 10:45 AM
  • CERTIFIED EXPERT
  • 53,855 POSTS
So it looks like you have 2 ignition coils that are bad, I would replace them and then clear the codes and check the other fuses.
P0351 - coil A / cylinder 1
P0354 - coil D / cylinder 4
Let us know how it goes.
Apr 13, 2026 at 8:49 AM
JOE1953
  • 773 POSTS
as i reported before the codes was P0351- P0354 i mean the codes are: P0351,P0352,P0353,P0354. do i need to replace all 4 coils? what can cause all 4 coils to go out at one time?
Apr 13, 2026 at 10:25 AM
  • CERTIFIED EXPERT
  • 53,855 POSTS
If you have all the coils codes at once, I would disconnect them and run a test, you may have one shorted coil taking the system down or the PCM is bad. Please go over this guide to help you with the testing.
Please go over this guide and get back to us.
Apr 14, 2026 at 7:36 AM
  • CERTIFIED EXPERT
  • 53,855 POSTS
Anything here?
Apr 25, 2026 at 8:24 AM
