No crank no start issue after removing a fuse while the engine was running
138,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
BRAD SECOR
I pulled out a fuse when car was running and it shut off put fuse back in, now it won't crank or start. have power but won't turn over or anything.
Feb 18, 2021 at 2:24 PM
I suspect you have an issue with the power to the starter but we need to start with finding out what fuse you removed in order to better know what the possible issue is.
Here are some guides that will help with this:
Feel free to get a picture or just tell me what fuse box and number fuse you removed. Let's start with this and go from there. Thanks
Jun 25, 2021 at 10:03 AM
