Fuse 22 keeps blowing?
150,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MIKEPROST
I’m trying to find out why the engine control fuse keeps blowing. It cranks but doesn’t start. I sprayed ether in the intake, and it will try to start so it’s a fuel issue too. I found a burnt o2 sensor wire on the upstream driver side. Could that cause the issue?
Feb 21, 2025 at 2:37 AM
  • 55,709 POSTS
Yes, the oxygen sensor gets 12 volts for the internal heater so if the wires are melted this can cause the issue. Are you sure it is not fuse 32 that is blowing? This is the fuse to power the oxygen sensor. There is a fuse #22 but is it for the radio and door locks. I would replace the sensor/wiring. Check out the images (below). Let us know what you find.
Feb 21, 2025 at 4:05 AM
MIKEPROST
So I guess it’s number 23 that’s blowing it the fuse box under the steering wheel I did more research it’s not what I thought it was. So, the truck cranks but doesn’t start. I have my scanner on it and it’s showing it has fuel pressure at the rail. I’m not sure where to go from there.
Feb 21, 2025 at 4:08 AM
MIKEPROST
But fuse number 23 does blow every time I turn the key to on.
Feb 21, 2025 at 4:09 AM
  • 55,709 POSTS
Please start a new thread for fuse #23 problem which does not have anything to do with the engine not starting. Let check to see if you have spark and injector trigger, here are two guides to go over to help:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Please go over these guides and get back to us.
Feb 22, 2025 at 3:34 AM
