The truck will move in reverse and when shifted to Drive it acts as if it's in neutral. Put truck back to park and remove fuse#19 and put truck on drive and it moves forward sluggish. All fluids are fine. Thinking it may be a wiring issue. Noticed a pink wire under dash driver side not connected like it was cut., is that a transmissions control ignition wire or MAF/IAT wire.
Jun 2, 2024 at 10:59 PM
