No crank no start
140,000 MILES • 4.6L • V8 • AUTOMATIC
COURTNEY93
So I have changed the starter, alternator, and the battery. I checked to see if the starter relay fuse was blown but there isn't a number 15 fuse in the fuse box under the hood. When I go to start the car it doesn't start there is a click noise for a second but it won't turn over. The lights come on but that's it. What do I need to do?
Dec 2, 2019 at 1:01 AM
Good afternoon,
The first thing you need to do is to charge the battery to 12.6 volts. You can get a trickle charger at a parts store for cheap.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
The start it up and check the voltage to the battery to see if the charging system is working.
Dec 2, 2019 at 3:35 AM
