Strong exhaust fumes when heat or A/C is on
1988 LINCOLN TOWN CAR
70,000 MILES • 0.5L • V8 • 2WD • AUTOMATIC
PATTY FREY
Why do I smell strong exhaust fumes when I run the heat or A/C? No check engine light on.
Dec 11, 2018 at 10:22 PM
Good morning,
Do you have any exhaust leaks in the system? A leaking exhaust will allow exhaust fumes into the car.
https://www.2carpros.com/articles/how-exhaust-systems-work
Are you sure it is not raw gas fumes? If it is, then you have an external fuel leak which must be addressed immediately. That is a big risk for a fire.
When you have the AC or heat on, it pulls in air from the outside and that is why you smell the fumes.
Dec 11, 2018 at 10:49 PM
