Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Citroen
Picasso
Trouble Codes
Fault code
2007 CITROEN PICASSO
250,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
VLADEZABA
MEMBER
my car 1.6 hdi 2007 shows me this fault
F03E I can't erase want to do or where is the problem?
Sep 18, 2019 at 7:40 PM
Experienced Mechanic
Welcome to 2CarPros.
Please understand that this vehicle isn't offered in the US, so my technical information is very limited
F03E Fault: absence of communication with the rev counter unit ECU or the odometer warning lamps unit
What I suggest is to start by checking the fuses to determine if one is blown. Here are a few links you may find helpful:
____________________
Let me know if this helps.
Sep 20, 2019 at 11:10 AM
VLADEZABA
MEMBER
i check all fusses are ok
Sep 23, 2019 at 9:46 PM
You will need to have the system scanned to determine the source. Do you have a scanner? If not, you really need to have this done.
Let me know if there are any other codes.
Sep 24, 2019 at 10:12 AM
Add image or video
Ask a new question
Engine won't start
Blower Fan — Not Working
