Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Fuel System
Fuel system is not working properly
2003 FORD EXPLORER
260,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
ANTHONY DOMINIC COLE
MEMBER
You have to hold the pedal to the floor then pump it hopping it will start.
Dec 16, 2019 at 7:48 PM
Experienced Mechanic
Good morning,
I would check the fuel pressure. It sounds like you have low fuel pressure on startup.
Are there any codes set?
How does it run once it starts?
Dec 16, 2019 at 10:29 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
