Fuel usage rather high
118,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
DOCTORE27
I just got this car as fairly used, the engine runs fine and no engine lights issues, but I have observed its rate of fuel consumption is rather worrisome! I have taken it to mechanic to have the chokes, spark plugs, Injector, air filter, sensor, checked and serviced, but the problem persists. What could be the problem?
Jan 10, 2019 at 4:20 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
What is your mpg?
Does the tailpipe blow out any smoke and if so what color smoke?
Jan 11, 2019 at 1:50 AM
DOCTORE27
Oh! I haven't taken time to calculate the mpg, but I surely will. No smoke observed from the exhaust.. thanks
Jan 12, 2019 at 2:13 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You might also just want to do a complete tune-up, spark plugs, fuel and air filter, pcv valve, and make sure there is no "check engine" light remaining on or coming on while driving and if so stop by a autozone or advance auto and have the engine trouble codes retrieved from the pcm.
When you get the mpg, post it here.
Jan 12, 2019 at 8:29 PM
DOCTORE27
Many thanks. the problem has finally been identified. I decided to fill the gas tank today when it was discovered the fuel filter panel isn't tightly covered, this was fixed immediately and now i'm enjoying the ride. Thanks so much guys. I'm so grateful.
Jan 12, 2019 at 8:51 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Great! Thank you for using 2CarPros.
Jan 12, 2019 at 9:58 PM
