Fuel too lean?
200,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
GABBY CANCASCI
My check engine light was on for fuel to lean. The mass airflow sensor got changed and it worked a little better than acted up again. Fuel pump got changed and now the car won’t turn on, but you hear the fuel pump turn on and gas was coming out of it.
Nov 20, 2024 at 8:36 PM
  • 55,554 POSTS
It sounds like the fuel pump is defective due to low pressure. When you say the car will not turn on, do you mean the engine will not crank over? (starter), or there are no lights coming on, or the engine cranks over but does not start and run? Please go over this video to help us see what is going on:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
This guide will help you see what can cause the elan mixture:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Can I ask if the exhaust system is leaking when the engine is running? If so, this will be the problem for the lean codes. Can you please shoot a quick video with your phone so I can see the problem? That way I can tell for sure what's going on. You can upload it here with your response. Also, what are the code numbers?
Nov 21, 2024 at 4:44 AM
GABBY CANCASCI
Those are the 2 codes that popped up after changing the motor in the fuel pump.
Nov 21, 2024 at 12:47 PM
  • 55,554 POSTS
Yep, both of these codes have to do with the fuel pump module so it must be defective. Here is the correct way to change out the fuel pump in case you need it. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Nov 22, 2024 at 4:22 AM
