Fuel tank sending unit erratic
140,000 MILES • 2.2L • 4 CYL • 4WD • AUTOMATIC
EDDIEJR
I recall a way to clean contacts and/or add jumper wire from the cargo area without dropping the tank.
Apr 13, 2019 at 4:01 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I'm not 100% sure I understand. There is a service port under the rear seat (See picture 1) which gives access to the pump. But, the level sensor is on the opposite side of the tank. (see picture 2). I don't recall there being a separate service port, but there could be.
You can inspect and clean the electrical connectors, but I know nothing about a jumper.
Apr 13, 2019 at 12:13 PM
