Where are the fuel tank pressure sensor located?
150,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
VELLIEVEIL
i can't find my evap pressure sensor/fuel tank pressure sensor. where is it located?
Jul 25, 2021 at 12:35 AM
SQM
  • 6,383 POSTS
Just to clarify, are you having issue refueling the car?
By pressure sensor do you mean the purge solenoid for the EVAP?
Are you getting any code?
https://www.2carpros.com/articles/evap-system-code-repair
https://www.2carpros.com/articles/how-emission-control-systems-work
There is also a refueling control valve that goes on the tank.
I have attached diagrams for the refueling valve, EVAP solenoid and other components for your reference.
Please let me know if you need any other info.
Jul 28, 2021 at 3:46 AM
