Fuel tank filler neck
2,559,067 MILES • V8 • 2WD • AUTOMATIC
LILFROST187
It is leaking at the bottom of the line. What is the cheapest way to fix it?
Mar 23, 2019 at 11:54 PM
JOETECHPRO
  • 705 POSTS
Hey LILFROST187,
Please can you upload a picture of the leaking area? then we can work out the best possible way to get it fixed cheaply.
Regards, Joe
Mar 24, 2019 at 2:49 AM
LILFROST187
Around that plastic ring.
Mar 24, 2019 at 2:59 AM
JOETECHPRO
  • 705 POSTS
Hey LILFROST187,
If it looks like it is leaking from around the plastic ring that is the tank sealing grommet for the filler neck.
I would advise replacing the grommet.
If it looks like it is the filler neck itself that has corroded and is porous you may be able to remove it, clean and then seal the area leaking.
I have included the instructions for removing/installing the filler neck.
Once removed you will be able to tell if you need the grommet or to repair/replace the filler neck.
Any further questions please don't hesitate to ask.
Regards, Joe
Mar 24, 2019 at 8:27 AM
