Fuel Tank cleaning
108,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
GOGOJUICE6
  • 76 POSTS
Hey fellows,
I believe my gas tank needs cleaning. I'm having problems with fuel pump and since I'm replacing it, I might as well clean the tank in the process.
What's the best way to clean it?
I would greatly appreciate your input. and as always, Thank you for your help...
Al
Mar 15, 2022 at 4:10 AM
  • 110,248 POSTS
Since you need to remove the fuel pump, the easiest thing is to simply drain the fuel tank. Once drained, you can simply wipe it out with a lint-free rag, or you can actually use hot water and a mild detergent to help clean it if there is a lot of dirt. If it's really bad, then you can even use a nylon-type brush to loosen dirt.
Drain the dirty water into a proper container and then use a lint-free rag to wipe out as much of the water as possible. Next, use compressed air to help dry it out as well.
Allow the tank to sit until fully dry before reinstalling it.
Let me know if this helps. Also, I attached the directions for the removal of the tank below. I'm not sure if you need them but figured I would add them just in case.
Take care of yourself and let me know if you have other questions and how things turn out for you.
Mar 15, 2022 at 1:07 PM
GOGOJUICE6
  • 76 POSTS
Thanks a lot for your input, Joe. Appreciated. According to Haynes manual. there's a fuel pump switch or "inertia switch" behind the glove box been looking for it to no avail...maybe you can help me find it...
Again, Thanks you guys for your help...Greatly appreciated...
Al
Mar 21, 2022 at 2:10 AM
  • 110,248 POSTS
Absolutely, there is one. It's designed to cut the power to the fuel pump in the event of an accident and can be reset if triggered.
I didn't realize no fuel was the issue or the pump wasn't working. I thought you just needed to know how a tank was to be cleaned. LOL
Regardless, I attached a pic below showing the switch and the reset button location.
Take a look at the picture below and let me know if that helps.
See pic below.
Mar 21, 2022 at 12:32 PM
GOGOJUICE6
  • 76 POSTS
hi, Joe. Thanks for such a fast response. This is what happened: I went to the store, got back in the truck and it wouldn't start (couldn't hear the pump click when turned switch to on position). I had it towed back home. A tow truck dropped it (actually dropped it, at about 2 or 3 inches from the ground, it was a boom tow truck,) he left, a few minutes later. I tried again and vroom, it was running like nothing had happened. so, i figured it must be that switch somehow tripped when I went to the store and it reset when the truck was dropped by tow truck.That's the only logical explanation I can think of. She's been running fine ever since. anyways, I think that fuel pump is going to give up soon, it's factory one (28 years old). Yes, the pic you sent me is a great help. Just like all the advice from all of you guys.
Outstanding advice for sure. keep up the awesome work, you guys.
Thanks a lot.
Mar 22, 2022 at 2:20 AM
  • 110,248 POSTS
Al,
You are very welcome. Ironically, one would have thought it would have caused the switch to kick off. LOL However, it may have done the opposite. There is simply an internal ball in the switch that moves in the event of an accident stopping the power to the pump. Yours sounds like it did the opposite. LOL
Regardless, thank you for the update, and please feel free to come back anytime in the future. You are always welcome here.
Take good care of yourself,
Mar 22, 2022 at 11:50 AM
GOGOJUICE6
  • 76 POSTS
Hi, Joe,
LOL.. right.? Illogical...like some humans ..LOL.. Thx for your outstanding and fast response..... Now, if it happened once, who's to say it won't happen again? I'm going to get a new one (not cheap) since I know where to look, (thanks to you) and keep it in the glove box, just in case...
As always, you guys are awesome, precise ,informative and fun....
Forget that video site....you guys are the real Pro's...
Thanks a lot to all of you,
Al
Mar 23, 2022 at 8:37 AM
  • 110,248 POSTS
Al, you are very welcome. People like you make it all worth it.
Take care of yourself and if things change, let me know.
Mar 23, 2022 at 9:32 AM
