fuel system short
225,000 MILES • 5.7L • V8 • AUTOMATIC
BIGGS
  • 16 POSTS
my 1993 5.7 buick roadmaster wagon has been stalling, sometimes it would start right back up and other times it would have to sit for anywhere between 5 to 90 minuets when it refuses to start the gas gauge would bounce around , i have replaced distributor brand new complete, idle air flow motor as it also had an idle problem which fixed that problem,replaced fuel filter and the next day it stalled once after about 3 miles and started right back up drove about 10 miles to work it sat there for 10 hours started right up drove it about 2-3 miles it stalled again and would not start but this time gas gauge is buried on full , please help me, what do i need to check and how do i test it ? im assuming its shorted out somewhere? thank you
Mar 22, 2017 at 2:26 PM
HMAC300
  • 48,601 POSTS
I doubt it's shorted check fuel pressure with a gauge auto parts rent it it should be 41-47 psi with 41 being minimum. it sounds like pump is shot. also the short may be at the wiring going to sender as normally a grounded wire will make gauge go to full. It can also be the sender which if you have to replace pump just get the whole assembly. see pic on how to diagnose for a sender.
Mar 22, 2017 at 10:56 PM
STEVE W.
  • 15,418 POSTS
Try this test, Jack the car up enough that you can get to the gas tank. Use a rubber mallet or block of wood or even a solid fist to give the tank itself a few solid whacks. Sometimes that can be enough to move the pump and start it turning again.
If it does start turning again DON'T drive it until you can replace it.
The likelihood of it acting up is directly proportional to your luck. With me that would mean the pump would stop the instant I pulled out in front of a loaded semi....
Mar 23, 2017 at 8:04 AM
BIGGS
  • 16 POSTS
thanks i will have to go through the process, steve that sounds easy enough sounds like your luck is about the same as mine lately i thank you for the info guys
Mar 23, 2017 at 1:48 PM
  • 55,746 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Mar 27, 2017 at 9:23 AM
