Fuel system problem
FRITZYBABE
  • 1988 FORD F-150
  • 5.0L
  • V8
  • 150,000 MILES
Noticed a constant humming sound coming from under neath the truck, could touch the inline fuel filter and feel the vibration. Changed the fuel filter, did not help, changed the HP fuel pump, started easier, but still humming, truck running fine. Then I removed cap from fuel reservoir to check filter, no filter in it. Since then truck starts easy, but then sputters and wants to shut off. The truck has a dual function reservoir, but the rear tank had been removed before I bought it. Can I just bypass the reservoir. Any help would be appreciated, Thank you
Thursday, November 23rd, 2017 AT 6:28 AM
  • 109,913 POSTS
Since you only have one tank, bypass the entire duel tank system and run a fuel line directly to the fuel rail.
Thursday, November 23rd, 2017 AT 7:04 PM
FRITZYBABE
Thanks for the help, truck runs great and doesn't make that noise anymore, I just wonder why a site I went to recommends a fuel line part 12inches long to bypass a valve less than 6, what a bitch.
Monday, November 27th, 2017 AT 3:52 AM
