1999 Ford F-150
TIM BEASLEY
  • 1999 FORD F-150
Engine Mechanical problem
1999 Ford F150 V8 Four Wheel Drive Automatic
Was driving and truck just died. Next day it started now will not start. It will turn over I replaced the fuel filter and the fuel pump is running I was told it may be the cam sensor or may have jump time. NEED HELP
Tuesday, August 25th, 2009 AT 7:48 AM
MJR346
  • 132 POSTS
Cam sensor won't cause a no start. Crank sensor on that model will.
You stated fuel pump runs, only for 2 seconds or while cranking?
Tuesday, August 25th, 2009 AT 8:00 PM
TIM BEASLEY
The fuel pump runs while cranking
Wednesday, August 26th, 2009 AT 7:29 AM
MJR346
  • 132 POSTS
By my guess then you are getting a crank signal.
If a v-8 jumped timing, you would have heard a lot of noise as the timing chains are a interference fit on that motor. However 20 years of those triton motors and I hadn't really seen one jump YET!
Check for fire by removing a coil, up ending it, pulling a plug out, inserting into the coil and have someone turn it over while you look at it. Back to basics of fuel, fire or compression. And unless you aren't getting any fuel (a fuel gauge I think can be rented from some of the national auto parts chains). You may have a sparking issue
Also, look at the theft light. Is it solid on, comes on and goes off, or does it blink?
Wednesday, August 26th, 2009 AT 8:52 PM
TIM BEASLEY
Yes the theft is blinking
Thursday, August 27th, 2009 AT 8:01 AM
MJR346
  • 132 POSTS
If the theft light is blinking, it will never start. Undo all the connections on a bracket near the battery, undo them clean them out with electrical cleaner at the auto parts store and dry and reassemble and see if it fixes it. Have seen that happen in the past as you describe.
If not, will have to diagnosed at a shop as it usually takes a pro level tool to retrieve codes from the cluster (this is the computer that holds the PATs system on this model) and to go from there
Thursday, August 27th, 2009 AT 7:10 PM
