fuel pump replacement?
66,000 MILES • 4 CYL • 2WD • AUTOMATIC
RICK ZAK
how do i access my fuel pump? Can I do it myself?
Feb 23, 2016 at 7:26 AM
WRENCHTECH
  • 20,760 POSTS
Here are the instruction in the diagrams below to do the job. Check out the diagrams (Below). Please let us know what happens. Take you time have a friend help
Feb 23, 2016 at 8:23 AM
MOTTA6918
i seem to notice fuel leaking from the rear and i looked under and it coming from the fuel tank. what needs to be replaced after dropping the tank on a2007 chevy equinox.
Dec 2, 2019 at 7:45 AM (Merged)
MOTTA6918
please reply cause its my elderly folks vehicle and its dangerous to operate vehicle with a fuel leak.
GMTECH
  • 537 POSTS
IS it your fuel filter leaking? Your vehicle is new enough that you have a plastic tank. I would get it to a dealer, they should be doing something for you if you are out of warranty, as again you should not have to deal with a fuel leak unless your filter is leaking which means it could be plugged.
2CP-ARCHIVES
  • 4,540 POSTS
Do you have fuel pump replacement instructions? I know my fuel pump is bad and want to do this myself if possible.
DOCFIXIT
  • 18,828 POSTS
Sure its not that bad of a job if you take you time here is a guide to help you step by step and instruction in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
