The vehicle in question ran out of gas and then had an `emergency fuel` added which indicated not to let the engine cool down before getting more gas in the tank. More gas was not added and then the car sat overnight, I have added some gasoline but the car now will not start.
Everything sounds like its running but there is no turn over. I have tried a few times with quick start spray which will run the engine for a few seconds before it cutting out again. I was hoping this would allow the emergency fuel to cycle through the system and get some of the gasoline in to run the car but it does not seem to be working.
I would greatly appreciate any information you can provide that may help with my issue.
Regards,
Zachary C
Regards,
Zachary C
Sep 8, 2017 at 12:37 AM
