Air in fuel system
87,625 MILES • 2.9L • 4WD • AUTOMATIC
JEAM
Air in fuel system, no leaks. Fuel reservoir?
Dec 4, 2018 at 1:34 AM
Good afternoon,
If there air in the fuel line then it could be coming from the fuel pump in the tank. If the pick up hose or line has a hole in it, it will draw air instead of fuel.
Try filling the tank with fuel and see if it still has air in it.
There is also a high pressure pump along the fuel rail. If there is a hole in the line between the tank and the pump, it will show air in the line.
Dec 4, 2018 at 1:49 AM
JEAM
I pulled in tank pump no holes or leaks. Fuel lines and o-rings look okay. Tank was full when it happened. Check valve in fuel reservoir is disassembled.
Dec 4, 2018 at 3:21 AM
Why is it apart?
Dec 4, 2018 at 3:24 AM
