Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Fuel System
Fuel Pump
Relay
Fuel system
1986 FORD F-150
40,000 MILES
PAULETTE GARCIA
MEMBER
1 POST
I have replaced the fuel relay and fuel pump, but the truck is still not getting any fuel.
May 21, 2018 at 5:35 PM
Experienced Mechanic
Good morning.
Did you verify power to the pump?
Did you check the fuses?
I will attach a wire diagram for you to view. I need the engine size.
If you have a test light or voltmeter we can do some checks to see.
May 21, 2018 at 11:38 PM
PAULETTE GARCIA
MEMBER
1 POST
5.0L dual tank XLT.
May 22, 2018 at 12:45 AM
Attached is a wire diagram for you to view. You need to verify power to the relay.
Image (Click to enlarge)
May 22, 2018 at 12:48 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
