fuel system?
180,000 MILES • 4.8L • V8 • 2WD • AUTOMATIC
MOSHE2002
With the o2 sensors disconnected and MAF disconnected the engine starts. What controls the fuel at that point?
Nov 5, 2022 at 10:04 PM
  • 110,248 POSTS
Once you disconnect the MAF, the computer compensates by following a predetermined program from the manufacturer. This prevents the engine from turning off while driving.
What is happening? Have you checked for diagnostic trouble codes?
As far as the MAF, if it runs disconnected and not with it connected, usually that indicates the sensor is faulty. Have you tried cleaning it?
Here is a link explaining how it's done:
https://www.2carpros.com/articles/mass-air-flow-service
Let me know what is happening and if there have been codes retrieved.
Nov 6, 2022 at 1:10 PM
MOSHE2002
The question was, what control the fuel when the engine is off at cold start, the MAF and o2 sensors are disconnected. the engine starts.
How the PCM know how to control the amount of fuel since the PCM don't know the amount of air?
Nov 9, 2022 at 9:53 PM
  • 110,248 POSTS
The circuit identifies a fault in the sensors. When it happens, it is designed to go into an open loop preset by the manufacturer to keep it running. I suspect that is what is happening when you disconnect the sensors.
Nov 10, 2022 at 10:53 AM
