Yesterday it would turn over but not start
199,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JUSTIN CORNELL
About four days ago my car started hesitating like it was running out of gas. Yesterday it would turn over but not start. In the process of turning over the car will almost start but as soon as you release the key it shuts off. Not sure if it is getting fuel. I already checked all the fuel system fuses and they are good.
Aug 27, 2018 at 3:40 AM
AL514
  • 5,700 POSTS
Hello there and thanks for using 2CarPros.com. You will next need to run a fuel pressure test if you think the pump failed. Here is a little article to help guide you through the process if you are up to testing it yourself. You will need a fuel pressure testing kit.
Aug 27, 2018 at 5:34 AM
JUSTIN CORNELL
Still not running. I changed the cam sensor.
Sep 4, 2018 at 3:48 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
As stated prior you should test the fuel pressure. You can rent one from your local auto part stores. It should be at 51 P.S.I. Here is a little article to help guide you through the process if you are up to testing it yourself. You will need a fuel pressure testing kit. Hope this helps and thanks for using 2CarPros.
Danny-
Sep 4, 2018 at 9:59 PM
