Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
S-10
Fuel System
Fuel Pump
Relay
when cranking the engine all fuel stops?
1992 CHEVROLET S-10
100,000 MILES
NUNYA56
MEMBER
1 POST
replaced fuel relays and installed new fuel pump. with key on fuel pumps good, but when cranking motor all fuel stops.
Aug 21, 2024 at 4:04 AM
Experienced Mechanic
When you first turn the key to the on position, the pump should prime for a second or two then stop.
Fuel will not be sent again until the PCM recognizes ignition and the engine starts.
Let me know what is happening. Are you able to get it to run at all?
Aug 21, 2024 at 1:03 PM
This can be caused by the ignition module failing, I would see if there is spark. This video can show you how:
https://youtu.be/baq_aEWNQ0Y?si=9Ig8obOtUB0A4R3d
Also, check all fuses to see if any are blown, here are the locations and how to change out the ignition module in the images below in case you need it.
Images (Click to enlarge)
Aug 21, 2024 at 1:05 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
