When I gradually push on the throttle it will hesitate then it will shut off?
90,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
SHANE BILLMAN
When it's at an idle it'll run but as soon as you gradually push on the throttle it'll hesitate then I'll go off. I replaced all the sensors and replace the spider fuel pump three times, filter twice injectors. what else could it be?
May 8, 2021 at 5:00 AM
  • 110,248 POSTS
Have you checked for diagnostic trouble codes? Also, have you checked for engine vacuum leaks and fuel pump pressure?
First, here is a quick video showing how to scan the vehicle:
https://youtu.be/InIlnsjOVFA
I realize most people don't own a scanner, but oftentimes a parts store will lend or rent one to you.
Next, make sure the fuel pressure isn't too high or too low. Here is a link that shows in general how to check fuel pressure:
Here is a link to help locate an engine vacuum leak:
I don't know what all has been checked so far. Sitting here, I'm even questioning if a catalytic converter could be plugged. Take a look through this link and let me know if it mirrors what you are experiencing:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know what all has been checked. If the things above haven't, that is where I would start.
May 8, 2021 at 2:32 PM
