Fuel spraying from around the exhaust manifold on cylinder six
401 MILES • 3.0L • V6 • 4WD • MANUAL
89YOTA
Just redid the timing belt after buying it from a guy who changed the knock sensor. Got it all back together and it’ll start, run a few seconds then cut off. We started smelling raw fuel so I had someone turn the key while looking under the hood and noticed fuel spraying from around the exhaust manifold on cylinder 6. Please help. I start a new job in a few days and need my truck on the road.
Nov 30, 2020 at 11:36 AM
  • 110,248 POSTS
That doesn't sound good. Listen, I attached a pic below. The fuel rail on this has two sides. I highlighted areas that could be leaking. Check these things and let me know if you see where it is coming from. Also, be careful.
Nov 30, 2020 at 12:10 PM
89YOTA
It’s not leaking from the rail. It’s pushing it out from around the manifold gasket. Could it be that I have vacuum lines hooked up wrong or have the driver side cam out by 180 degrees?
Nov 30, 2020 at 12:18 PM
  • 110,248 POSTS
That honestly doesn't make sense. The intake is under a lot of vacuum. It wouldn't push fuel out. Could it be the injector where it mounts? There is an o-ring that could be bad or the insulator isn't properly installed on the intake. See the attached pics.
If possible, could you take a pic of where you see the leak and upload it for me to see?
Nov 30, 2020 at 12:29 PM
89YOTA
Yes I can. It’ll be in the morning before I can get you pics.
Nov 30, 2020 at 12:34 PM
  • 110,248 POSTS
Sounds like a plan. I have a feeling it is at the injector and appears to be from the manifold. The intake has a strong enough vacuum going through it to prevent what you described.
Dec 1, 2020 at 10:06 AM
