Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
LS
Fuel System
Fuel Level Sensor
Replace/Remove
Fuel sending unit
2004 LINCOLN LS
225,000 MILES
RUSSELL WALKER
MEMBER
1 POST
Replaced pump, fuel pressure regulator, filter, starts then stalls. need to know how to check the fuel pump sender on the driver side?
Aug 7, 2019 at 8:46 AM
Experienced Mechanic
It sounds like you want to check the fuel pressure? This guide will help with the location of the pressure port in the diagrams below:
Images (Click to enlarge)
Aug 8, 2019 at 5:18 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
