Fuel sending unit
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LESQUENAZI
  • 25 POSTS
Just replaced sending unit due to faulty reading. Now with new sending unit getting a full tank reading even though fuel level is going down. How do I fix this?
Nov 25, 2019 at 11:56 PM
  • 110,248 POSTS
Attached to the pump and sending unit is the level sensor. It is nothing more than a rheostat which changes resistance and power supply based on fuel level. I suspect that the float that is attached to the rheostat (level sensor) is stuck in the full position. It can happen when you reinstalled the sending unit without you knowing.
I hate to say this, but I would remove the pump assembly again and inspect to make sure nothing was bent or stuck.
Take a look at the attached picture. I circled the float and the sensor. That is what I would check first.
Nov 26, 2019 at 12:16 PM
LESQUENAZI
  • 25 POSTS
Yeah it was binding. Fixed, thanks.
Mar 22, 2021 at 2:16 AM
  • 110,248 POSTS
Glad to hear you got it fixed. Please feel free to come back anytime in the future if you need anything.
Mar 22, 2021 at 11:34 AM
