Engine stalling, erratic fuel gauge
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOMMIEGAGE
Car started stalling out with any cause. Stalled out the other day and would not start. I the truck took it to a shop, shop said the fuel sending unit was not right, either not put it properly, or going bad. What I have read, the fuel sending unit will not make a car stall as long as there is gas in it. I picked it up from the shop, filled it up, and it stalled out within the quarter of a mile from the gas station to home. My question is, will the fuel sending unit make a car stall out, even at high speeds? It does stall while idling, and also while driving sometimes. Also, the fuel gauge was acting erratic for the first time today. Filled it up, fuel gauge dropped to empty, then shot back up to full.
Dec 1, 2017 at 1:02 AM
HARRY P
  • 2,292 POSTS
The fuel sending unit is also known as the gauge sending unit. Basically, it sends a signal to the dash to indicate how much gas is in the tank. The sending unit is built in to the fuel pump assembly. It's possible that that's what the mechanic was referring to. If you replace the pump, both issues should be addressed.
Dec 1, 2017 at 11:01 AM
