FUEL SENDING UNIT
225,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BIGGS
  • 16 POSTS
if i suspect a bad sending unit can i just unplug it as it has a separate plug to the fuel pump, will my run and by unplugging the sender and it fixes the stalling problem then i would know its the sender and not the pump that is giving me the stalling out problems, will this work for testing?
Mar 27, 2017 at 4:05 PM
HMAC300
  • 48,601 POSTS
no it also connects the pump. check fuel pressure with a gauge auto parts rent it. if you are getting hesitation a gauge will not cause the problem. pressure should be 41-47 psi minimum see link
Mar 27, 2017 at 11:23 PM
