Where are the circuit opening relay and inertia switch located?
160,000 MILES • 2.6L • 4 CYL • 4WD • MANUAL
PAPERMIKE
Fuel relay and fuel pump test. Where are the circuit opening relay and inertia switch located?
Jan 12, 2023 at 12:56 AM
  • 55,808 POSTS
I do not see a circuit opening relay or an inertia switch. Here are the engine control wiring diagrams so you can see for yourself. Can i ask where you found this information?
Jan 12, 2023 at 9:39 AM
