Fuel relay location
500,000 MILES
STEVEN MICHAELSON
  • 5 POSTS
Where is fuel relay located on my car listed above? It has a 3.0 liter engine.
Sep 12, 2018 at 8:42 AM
  • 110,251 POSTS
The fuel pump relay is not a typical relay that can be replaced. It is part of the Integrated Control Relay Module and is located at the front of the engine compartment, on the upper radiator support. I attached a picture of its location.
I hope this helps. Let me know if you have other questions.
Sep 12, 2018 at 12:07 PM
STEVEN MICHAELSON
  • 5 POSTS
How can I test it to find out if it is causing fuel pump not to work? I cut the fuel shut off wires and spiced them together. Put test light on wires and got nothing. So as far as I can tell I do not have power to that point.
Sep 12, 2018 at 12:55 PM
  • 110,251 POSTS
Here are the diagnostic procedures for testing the relay module. See pictures.
Let me know if it helps.
Sep 12, 2018 at 1:16 PM
STEVEN MICHAELSON
  • 5 POSTS
Thank you so much for your time on this issue. Could you please send a picture. That is not blurry I cannot read anything on the picture.
Sep 12, 2018 at 7:21 PM
  • 110,251 POSTS
Hi again. I will try again. I am not sure what happened, but they are clear on my end. Let me know if this is better. You may need to copy and paste it into a paint or word document so it can be enlarged.
Sep 13, 2018 at 12:01 PM
STEVEN MICHAELSON
  • 5 POSTS
They are clear. Thanks
Sep 13, 2018 at 12:03 PM
  • 110,251 POSTS
Good. Let me know if you need help or additional information.
Sep 14, 2018 at 12:10 PM
STEVEN MICHAELSON
  • 5 POSTS
Five wires that go into fuel tank. Which one do I jump to test fuel pump?
Sep 19, 2018 at 8:43 AM
  • 110,251 POSTS
Hi again. The power supply should be a pink and black wire. See the attached table for wire designations and colors.
Sep 21, 2018 at 1:38 PM
