Fuel Rail mounting bolt broke off leaving the bolt inside the manifold, can I get a part number to get the size?
130,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
KMAN1101
The head of one of the fuel rail mounting bolts that holds the rail to the intake manifold broke off leaving the bolt inside the manifold. I don't want to pull any of the other bolts (since I don't have to) in case they are seized as well. I am trying to find the correct replacement bolt or at least the size so I can have a new one ready to go in after I extract the old one. I have searched all over online and tried finding diagrams so I could get a part number to get the size, but I cannot find anything.
May 4, 2025 at 3:48 AM
MECHTRIX
  • 570 POSTS
I believe its 6mm x 1.0 pitch and 16mm long ...wrench size should be 10mm.
May 4, 2025 at 12:58 PM
MECHTRIX
  • 570 POSTS
Oh and they're super common you can get them 2 for a dollar at any hardware or auto parts store. Good luck, hope this helps.
May 4, 2025 at 1:01 PM
KMAN1101
Thank you, guys for the quick reply! I’ll pick one up, but I think it’s smaller than a 6mm and it only as an 8mm head. No worries though, I’ll try to pull another bolt and use my gauge.
May 5, 2025 at 9:41 AM
MECHTRIX
  • 570 POSTS
Yep 6mm bolts have heads that are 10mm and also 8mm too it vary common on those. good luck
May 5, 2025 at 2:33 PM
