Fuel rail connector removal
200,000 MILES • 4.0L • 6 CYL
GETTHEJOBDONE
Fuel line connector connects to the fuel rail cannot get it off. It is not a clip the bottom piece turns top piece cannot get it to disengage.
Nov 18, 2018 at 8:17 AM
Good evening.
Can you post a picture of what you see?
Are you using the correct tool to spread the spring release?
Nov 18, 2018 at 8:32 AM
GETTHEJOBDONE
Where is I cannot see where it splits apart the bottom part spins in a circle the number is j GR on the fitting probably just manufacturer. Send the pictures who would you think. Thank you for your help. Truck has been sitting a ring must got gas stop leaking still need to know how to take it off. Please
Nov 19, 2018 at 4:51 AM
Is that the fuel line or the PCV valve?
Nov 19, 2018 at 4:58 AM
GETTHEJOBDONE
Fuel line sir.
Nov 19, 2018 at 6:02 AM
