Code P0203, where is the Fuel rail circuit 3 located?
222,478 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JOSH.JONES
Where is circuit 3 / fuel injector 3 on my vehicle? How are the injectors numbered? Can I get a picture of this diagram?
Oct 19, 2024 at 5:27 PM
  • 55,684 POSTS
Yep, this ocde is telling you there is a bad connection @ #3 which usually means a bad fuel injector.
The code P0203 on your 2011 Ford Escape refers to an issue with the Fuel Injector Circuit/Open - Cylinder 3.
#3 is the last cylinder on the right side of the engine. Here is how to replace the fuel injector. Check out the images (below). Please let us know what happens.
Oct 20, 2024 at 5:21 AM
