Fuel rail
156,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ROGERMM65
  • 50 POSTS
Can i spray all the junk from around fuel injectors with 2+2? if not what's okay to use?
Aug 6, 2020 at 2:51 PM
Good morning,
Yes, you can use 2+2. Make sure you let it sit for a while to evaporate before starting. If there is heat or a spark leak, all that spray would ignite under the hood and you would have a fire.
Are you having a issue with the injectors?
Aug 7, 2020 at 2:36 AM
ROGERMM65
  • 50 POSTS
No problems with injectors yet. started to replace cam cover gaskets , wishing i would have pulled the motor now. back yard mechanical technologies at work here. darn weather .
Aug 7, 2020 at 12:25 PM
I understand.
I just do not want you to start a fire. 2+2 is great stuff and works as well as brake kleen. They are just very flammable.
The lower housing to the head has a gasket but the upper cover does not. You use sealer. The gray sealer is what is used from the factory.
Aug 7, 2020 at 10:48 PM
ROGERMM65
  • 50 POSTS
When #1 cylinder popped pressure piston was down i turned it clockwise until at TDC, bottom crank mark was pointing north as book shows, but cams were pointing south. Has this Chevrolet been running for years with with the 2 cams 1/2 rotation out?. It has always shook hard at stops?
Aug 14, 2020 at 1:21 PM
Okay, since we are off on another area of concern, please go back to the beginning and start a new question on the timing chain.
I will be glad to help with this but you need to start a new question.
Aug 14, 2020 at 8:52 PM
