there is a rapid ticking sound coming possibly coming from the fuel pump, fuel pump relay or wiring?
237,787 MILES • V6 • 4WD • AUTOMATIC
SMITHEE
  • 8 POSTS
I’ve been having a rapid ticking sound coming from the fuel pump relay, it lasts for about 5-10 minutes, then car starts right up and runs great. I bought a new fuel pump, and 2 new relays still makes the ticking sound. I have a feeling it’s something with the wires or wiring. I just have no clue where to start if anyone can help, I would really appreciate it.
Mar 2, 2025 at 1:48 PM
  • 55,837 POSTS
The fuel pump relay is controlled by the PCM which might be going bad. Do you have any trouble codes?
This guide can help:
Also, when trying to start the engine do you have a security light flashing? Here is the wiring diagram for the fuel pump relay and PCM so you can see how the system works. I would also check the ground for the relay which is on the rear of the engine block which I have marked on the diagram as well. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Mar 3, 2025 at 4:25 AM
SMITHEE
  • 8 POSTS
I’ll try that and when it does the clicking the engine light comes on but once it’s done doing the ticking it turns off. I tried to hook up my scanner tool while it’s doing but can only get codes while it’s running.
Mar 3, 2025 at 5:00 AM
SMITHEE
  • 8 POSTS
This is what it does.
Mar 3, 2025 at 6:53 AM
  • 55,837 POSTS
Thanks for the video. Is the ticking duration the same each time? If so, it looks like the PCM needs to be replaced. Here is how, you can get a preprogrammed unit by searching Google or Ebay. I would also check the grounds from the battery to the engine and chassis/body.
Mar 4, 2025 at 2:31 AM
SMITHEE
  • 8 POSTS
Yeah, it’s about same amount of time each time it does which it only does it after not driving it after a few hours and the ground to the chassis is good because I did have to replace that since I touched it and broke off.
Mar 4, 2025 at 4:49 AM
  • 55,837 POSTS
Yep, the PCM is the only thing I can think of that would do that. Let me know after you have replaced it.
Mar 5, 2025 at 12:45 AM
