Fuel pump wiring harness diagram needed
200,000 MILES • 2.7L • V6 • AUTOMATIC
RICKEYBOBBY494
  • 15 POSTS
I removed the five-wire plug and three of the wires red, black and pink I think are not connected. I need to know where the five wires go in the tank plug.
Feb 20, 2022 at 4:04 AM
WENDY W
  • 86 POSTS
Hello!
I’ve attached diagrams for the fuel pump motor and sender unit (below).
I don't see a pink wire at the connector. Is it possible it could be faded red?
It seems like the wiring order could be:
1. Blue with orange stripe
2. Blue
3. Black
4. Red
5. Black
Please feel free to attach a photo of your connector and wires.
You may find the following repair guides helpful:
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Please let us know if we can provide any further information.
Thanks, Wendy W
Feb 20, 2022 at 11:14 PM
RICKEYBOBBY494
  • 15 POSTS
Thank you so much, I think I have enough.
Feb 23, 2022 at 11:42 PM
WENDY W
  • 86 POSTS
You're welcome! If we can be of further assistance in the future, please let us know.
Thanks, Wendy W
Feb 24, 2022 at 12:13 AM
RICKEYBOBBY494
  • 15 POSTS
Hi Wendy, the fuel pump went great. I got it wired back up, but I have a problem with intermittent rough running and hard starting. Two times in the last couple of weeks it has conked out on me, and I got it started back and it was running really rough like it was missing on one cylinder then after a few minutes of high idle and revving it up the miss went away it started idling smoothly and running good. now it's happened again after about 2 or 3 weeks. so, I'm wondering if there is a computer or spark or stuck injector. the OBD will not give codes to a reader, and it doesn't look like there's a fuse for the OBD. Any help would be much appreciated.
Feb 28, 2022 at 1:51 AM
WENDY W
  • 86 POSTS
Hello!
I'm glad to hear the fuel pump repair went so well. We would be happy to help with your drivability concern as well. Would you mind starting a new thread with this question, please? That way if someone else has a similar issue, the solution might be easier for them to find.
You can just follow this link:
Thank you so much! Wendy W.
Feb 28, 2022 at 4:31 AM
