I need the wiring color codes for the plug going to the fuel pump?
50,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
DAVID ROBERTS2
Hi, i need the wiring color codes for the plug going to the fuel pump please. While changing the fuel pump I tore the wires out of the plug that goes into the fuel pump. bought a new plug but can't remember what wires goes where. TIA
Aug 13, 2021 at 7:46 AM
I am attaching not only the wiring diagram but also the connector view as I suspect this is what you will really need as it includes the wire colors and position in the connector.
Also here are a couple guides that will help with some info doing this repair and test it if needed.
The video is clearly of a head light connector but that is not the point. The idea is just to show how to solder the connector in the proper way. It also talks about some other ways of connecting the wiring.
https://www.youtube.com/watch?v=PxA5wczsCVo
Please run through this and let mw know if you have questions.
Thanks
Aug 13, 2021 at 12:59 PM
